- Not to dissuade the "my fog particle is bigger than your fog particle" disussion, but I thought I'd give a 12-month update to my Rigid LED project.
What I installed:
- Four Rigid Dually floods (not D2, rated at 1,200 lumens / 15W each) on a lightbar.
- I use them extensively on dark mountain roads. Not technically "off road", but in areas with very little oncoming traffic.
- Also played around with a few other LED lights as well as HID driving lights that I've used in other applications.
Mechanical/Electrical:
- Wired all four to a single relay (15Wx4 = 60W), with a master switch and toggled on with my conventional high beams.
- The mounting system has been robust, easy to mount, easy to align, they don't move around when tightened.
- The physical lights have held up well, housings are very solid.
- While I've had no problem with fogging/seals on my lights, two different friends with Rigid's have had internal fogging requiring light replacement. Rigid did this under warranty, but a hassle none the less.
- The low current and instant fire is definitely a nice feature.
- The lights look great and lots of people check them out and have questions about them.
Light output & pattern:
- Four 1,200 lumen floods definitely provide good near-feild lighting, but as mentioned previously, not great throw down the road. Probably should have done two spots/two floods instead.
- Light pattern is circular with zero cutoff. Lots of light output going where it isn't needed unless you are searching for squirells in trees.
- As cornering/mountain road lights, they are excellent.
Compared to other lights:
- A pair of Kragen HID's definitely work better as driving lights. Great light output, but more importantly, good beam pattern and some cutoff. But all plastic construction and I didn't want big HID's on this particular truck.
- 1,300 lumens is pretty wimpy for a four LED light these days. Even the Dually's ar a bit wimpy at 2,600. Lots of new 4-led lights out there rated at 3,600 lumens running Cree XM-L T6's. Some are quite expensive, like the Baja Designs Squadron at $330 per light, but there are also some import lights that seem quite decent for more like $85 each. I installed a pair of these imports and am pretty impressed with the light output. They also don't have any sort of beam pattern, but they are much brighter than the dually's per light. Compact as well.
Import LED installation:
- I whipped up some quick brackets to mount them behind the grille on my truck. These brackets were prototypes, intended to be cleaned up a bit, painted, etc., but as sometimes happens, if the prototype works well enough, they just end up staying in place.
- For a budget light solution, think a pair of the import 3,200 lumen LED's and a pair of Kragen HID's would be a great combo for less than $400 total.
