Not a bad theory though... the mod is basically to correct some of the bad heat management in the Leadlights.. a certain part is causing heat dissipation to be non-existent and needs removing and then a quick re-alignment again. Thats all I say for now... /ubbthreads/images/graemlins/smile.gif
anyone else sitting here looking at their 105 totally taken apart trying to figure this mod out? past couple hour i've taken mine apart about 4 times down to every piece.. then back together because i just cant see what to do =)
which glue, the clear holding the ir filter on, or the solid white "thermal" putty.. not like the solid white crap will do much of anything.... thats the only thing i can see to remove =)
You still haven't told me what happens when you attach two ND crystals together to produce more 1064mw.
I think there has to be a realistic solution to the efficiency problem these lasers have. There's no reason for a mere 10% conversion of IR to Green. I'm sure this loss is due in part to the cost of the crystals and the lack of power required for a laser pointer. Get longer crystals and output more power.
