pointedspider
- Joined
- Jun 17, 2012
- Messages
- 24
ima try that photobucket
how do I insert a pic?
The M60 series is discontinued. Oveready still sells them. Elzetta does too.Browsed their site but could not find the model "M60F". They must continually change model codes after each run. I was hoping they had just the diffusion lens
for sale as an accessory but no such luck.:shrug:
At least I know what to look for now. thanks
Those lenses are TIR optics. There is no reflective coating. The light reflects off the molecular interface between the optic's rear surface and the air surrounding it.I'm actually still a bit fuzzy on the beam angle specifics. If it's the reflector part or the beaded lens part that will determine either a 45 degree or a 60 degree beam.
The pictures at Intl-outdoor unfortunately do not show the inside surface of the "white housing" if it has a reflective finish or just the same as the outside.
I was planning on discarding the housing part and simply sticking the beaded lens in front of my XM-L drop-in's OP reflector, hoping for the desired result.
Total internal reflection is an optical phenomenon that happens when a ray oflight strikes a medium boundary at an angle larger than a particular critical anglewith respect to the normal to the surface. If the refractive index is lower on the other side of the boundary and the incident angle is greater than the critical angle, no light can pass through and all of the light is reflected. The critical angle is the angle of incidence above which the total internal reflection occurs.
