dano
Well, thanks to the good folks at TTS I received a Streamlight Strion from UPS...
Overall, it's a mini Stinger. Similar construction, body design, reflector design and bi-pin bulb (NOTE: The Strion uses part number 74914 {3.7v/6.12w}for the bulb while Stingers use a 75914 {3.6v/6w} part number for the bulb. You may get a bit more light from a Strion bulb when used in a Stinger).
The tailcap switch is similar to the TL series. The battery stick is a tiny Li-Ion (2000MAH capacity) with the positive and negative terminals situated on one side. Has a glass lends, and the reflector looks like it unscrews from the bezel ring, unlike Stinger's where the assembly is a press fit.
Sorry, no beam descriptions, yet. It's charging...
--dan
--dan
