awenta
Alp, did you try the newer 3.04a (IIRC) from sb?
Also yaz get thicker or makeshift leads for more accurate high draw applications.
player:
That mod is along the lines of what I had in mind but to use a simple driver and battery set up. My thoughts on the voltage moniter is that is has a higher cost than value and takes more effort for little gain. I think (but am not sure) that if you were to do the mod and found you wanted to add that in after that it would not be too much extra effort to do (provided you could get the heatsink out easily and didnt glue/epoxy anything ot the sidewalls). I made a similar mod with a 2D light:
http://www.candlepowerforums.com/vb/showthread.php?319319-2D-mag-modded-to-6AA-XM-L
I had envisioned you doing similar but with 3D cells instead of the AAs I used.
Why does it seem like most people are modding the 2D and not the 3D? Is it because the 2D is a cheaper light to by?
Illumination supply shows back order for the LED. Why is board size important, is it just for centering? I've seen 14mm, 16mm, and 20mm. I was wondering about asking the guy who makes the heatsinks if he could make one with a 20mm center and I could get the Cree XM-L U2.
I was wondering why the heatsinks are not made out of copper, they would have better conductivity and thermal dissipation then aluminum.
or get der witchel 3xm-l drop in, (2500lm) it will reqire some soldering, and switch modification, but it isn't hard, step by step instructions are on this site, more than one thread, you can run it from 4x26500 cells in 3d tube, or 3x26650, pbly the brightest mag drop in available.
