I ended up with the litefuze 20 watt panel and the 1270 upg battery (7.2 ah). As I mentioned before all I want it to do is power a battery and phone charger. If this one poops out and I'm still into the solar thing maybe I will pickup a lithium battery. I am also curious about running a small fan. Are there any that work well with direct drive from the panel? Maybe a large pc fan might work with a regular setup.
I also ordered a mc4 connector , blade fuses, and a female cigarette adapter but other than that I'm not sure what size wiring to use. Where do you find the nice premade cables with the rings? Also unsure of what I should use for the battery connectors. Maybe my questions are quite basic but I just want to make sure its done right.
