TranquillityBase
- Joined
- Jun 12, 2005
- Messages
- 3,741
(1): yes,Wouldn't a 4 die Ostar 13.2/4 = 3.3 Vf per chip equal four Lux III's (1), Seoul (2) or Cree (3) LED's?...
I have a question for you pros:
I'm builing a 12x XPG spotlight, 2 sets of 6 leds in series, each powered by a blue shark.
The battery is a 2x 7 Cell 8.4v Nimh connected in series, totalling 16.8v. When the batteries are fully charged, the Vout is only around 1 volt above the Vin, is this ok??
Or should I change the battery to a 6+6 cells, 14.4v instead?
Thanks.
Your input voltage needs to be *below* the VF of the LED's at all times. Also if your planning on using a remora to have 3 levels of brightness you may even want to have a lower voltage input.
Mac
Then it doesn't matter if it is lower by only 1 volt? What happens if this Vin is higher than the leds combined Vf?
I'm not going to use remora, just blueshark adjusted for 980mA output.
You can't use 14 cells in series with 6 led's. 14 cells hot off the charger can be up to 20v. Figure 3.0v per led to be safe = 18v. Use 2, 6 cells packs for 12 cells in series.
Mac
Can I adjust the onboard trimpot on the fly? (while it is ON)
I kind of thought !
first SHARK with bridge, second SHARK without bridge, ...
Mono
Hi I found this post in another thread, but it looks like no one is following that thread anymore. Could someone please help?
I'm still a bit confused on how to do this.
I still remove the trimpot from both sharks and bridge the gap of the to 2 pads correct?
Led + and LED - from both boards wired together to the LEDs?
Vin and Vout from battery connect to both boards?
And the ONLY connection I need between remora and the SECOND blue shark is PWM?
So I only wire remora V+ from remora to the first shark correct?
What would happen if there was a jumper on the slaves trimpot?
