@warmurf - given the high voltage, the draw is actually very reasonable. I measured roughly 1.6A draw on Max so I'd recommend using HKJ's excellent cell comparator:
http://lygte-info.dk/review/batteries2012/Common18650comparator.php
and selecting the 2A button then clicking through various cells to see which gives you the best runtime (longest line) or highest v output (tallest line overall) depending on your needs. I used to think that just 'cuz a cell was higher in capacity and was able to best another cell at a higher draw that it'd naturally beat it at lower draw but as you play around with his tool, you'll come to see that's not always the case.
@Jabberwocke - welcome back from your hiatus! The cells feature button tops so can be used in the TM11 but again, with the usual caveats that go along with using unprotected cells. Despite its parallel arrangement, there still is a chance (even if a reduced one) that one cell can be discharged disproportionately from the others. If you follow safe LiIon handling practices (monitoring voltage of each cell after charge, not overdischarging, etc.) then I don't see why these cells can't be used. If however, you'd rather not take a chance at all then I'd recommend just selling them and getting protected cells for your TM11 as well.
Likewise with the charger, per the past few previous replies, if you don't feel comfortable with the potential risks of unbalanced cells then best to remove the batteries and charge them individually with an external charger.
My bottom line on this is that I personally feel comfortable using the supplied charger as well as the unprotected cells since I'm pretty careful about checking cells, etc. but in this litigious society, one would be foolish to recommend that unconditionally to another in case something does happen so ultimately, you'll need to make that decision for yourself.
Cheers,
Tim
