Steve K
5.8v float charge seems high for 4 nimh AA's. I used to charge my nicads at 1.35v/cell, and nicads don't mind float or trickle charging. If I were you, I wouldn't change anything right now, but if the batteries don't last long, consider dropping the voltage.
Using a charger like this can be tricky if you are using a series regulator. At a given speed, when the current decreases, the dynamo voltage increases. For my Schmidt, if I used a 98v zener to clamp the voltage, the dynamo still produced more than a few milliamps of current (at high speeds). If you want to clamp the dynamo voltage, it's best to do it at low voltages. If you clamp at 25v and the dynamo still produces 200mA, then the zener has to dissipate 5 watts instead of the 3 watts that would be dissipated at 6 or 7 volts.
Steve K.
Steve K.
