larryk
I would like 1 maybe 2.
Why hasn't someone just transplanted one of those adjustable ballast or a common 50W ballast?
Also, be careful about overdriving pressurized glass chambers. You might consider getting some DL-50s or the fatboy versions of those if you can find 'em, but you'll have to construct a spacer or adapter, they are p32/d.
2filty3
What would be the effect running the light with mod from a 4s 14.8v nominal (16.8v topped off) Lipo pack. Too much power or ok? I run my light now occasionally by plugging the cig plug into my Lipo battery setup and it works fine...
My opinion a 30 w low would be great because the run-time on these lights is so low, especially at even higher outputs. I have 4 or 5 of these laying around and the batteries are all dead.
Mine all have the Hi-Low switch. Can't remember, this mod work on these or only single mod version.
How is this mod effected (if any) when you plug the cigarette plug in.
thanks!
thanks!
have you opened a stanley? if so, then you'd know why, lol.... theres not alot of breathing space in that casing, and along with the ignitor, would be a tight fit, not to mention theres NO ventilation at all. i'm not say'n it can't be done, but would be a tight and risky mod. if i were to do it, i'd make sure to keep as much of the original hardware intact as i could so i could always return it to stock when the new ballast goes
and at 30 mins runtime on the stock 35w system, i can't see getting more than 15mins outa the SLA, so..... upgrade there as well
