SUNWAYMAN G25C- Super-compact Dual-button Powerful Flashlight
sunwayman
1000 Lumens Dual-button Super-compact Powerful Flashlight
SUNWAYMAN G25C is the upgraded dual-button switch model with improved performance and easy-operation. Stainless steel soft-contact dual-button at the tail, main button controls on/off and the other one to select desired output mode, very intuitive user interface. The Strobe mode can be activated directly even with the light turned off for emergencies. Fitted with CREE XM-L2 U2 LED, max output reaches 1000 lumens. Elaborately-designed and precisely-machined light body, this is one surprisingly-compact 18650 model, easy to grip and carry daily. The upgraded G25C is your ideal lighting tool for all of your adventures!
Features
● CREE XM-L2 U2 LED, with a lifetime of up to 50,000 hours;
● Tail cap dual-push-button switches, one to control on/off, the other for selecting desired output mode, three types mode-switching;
Output & Runtime
High- 1000 Lumens, 2 hrs.
Mid- 150 Lumens, 6 hrs.
Low- 16 Lumens, 80 hrs.
Strobe
● Constant current circuit, constant output
● Effective range of 208 meters
● Uses one single 18650 or two CR123A batteries
● Working voltage: 2.8~6.4V
● High quality metal smooth reflector maintains great throw distance and spread with an ideal beam pattern
● Dimensions: 113mm (length) x 30mm (head diameter) x 25mm (tail diameter)
● Weight: 93.4g(battery excluded)
● Aerospace-grade aluminum alloy, Stainless Steel retaining ring on the top
● Military Specification Type III- hard anodized body
● Waterproof, in accordance with IPX-8 standard
● Ultra-clear tempered glass lens resists scratches and impacts
● Accessories: Clip, Lanyard ,O-rings
djburkes
Arkansas
This is a beautiful light but it would be nice if you could find some way to implement deep carry pocket clips on your lights. I have a C22C and I really like it but I don't carry it like I do my Zebralight because of the pocket clip. Also, going forward, I can't seem to understand why Sunwayman is still using XM-L2 U2 LEDs instead of U3, U4, or even XP-Ls. I'm sure you could also pump a few more lumens than 1,000 out of that light. All of these modders are making big dollars off of your lights because they Implement the newer hardware and take your lights to the places they should be able to go. This is something you should be able to do from the factory.
buddyrohr
Removed by his own request
i would also like to see a more secure attachment like double screws on the clip rather than just an interference or clipon fit. personally i am lusting after a v11r but this is sweet also
Ernst from Germany
Only 3 steps of Brightness are not a hell of a lot.
1000 Lumen and then 150 Lumen, I mean there sould be a 450 or a 500 Lumen step.
Best greets from germany,
Diffuser
Pennsylvania
Just placed an order for one today. I really like the dual button design. I also like how the med mode is set for 150 lumens great for what I am going to use it for.
CelticCross74
Fairfax Va
113mm long is indeed very compact! I believe that is the same length as the MH20! Still 3 modes plus strobe only? 1000 to 150 lumens is a massive drop enough to throw ones vision off a good bit for a few seconds. Love the switches. The clip blows sorry the compact competition have deep carry clips. No sheath? Seriously? Cannot complain too much even my mighty ZL SC600 MkII came without a sheath but then again my MH20 came with a good sheath AND deep carry clip as well as 5 well spaced modes. You almost got me on this one Sunwayman but the lack of modes and the fact that quite a bit of the light would be sticking out of my pocket kill it for me.
ktsl
No lanyard hole
no moonlight mode
no beacon mode
What a pity. Could have been a perfect light.
