HKJ
[size=+3]EnerPower+ 32600 6000mAh (Yellow)[/size]
Official specifications:
This size is same diameter as D cells, but slightly longer. The capacity is fairly low for the size of the cell (This is as expected).
The discharge curves looks fairly good, but not perfect, there is a capacity difference between the cells.
The cell did not really get warm, the protection circuit tripped before I could draw enough current to really heat the cell.
[size=+3]Conclusion[/size]
With larger size LiIon batteries there is not much extra capacity, but the voltage stays high for longer.
Performance is as expected for this size battery.
[size=+3]Notes and links[/size]
The batteries was supplied by Enerpower for review.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Compare to 18650 and other batteries
- Nominal voltage: 3.6V
- Nominal capacity: 6000mAh
