Hi
I am running some output/runtime test on a new bike light, running either a single 18650. And I must say that I am well impressed withe the Fenix 2600, in my test, it outperform AW2600, INT 3100 (advertised as Panasonic cell), PluzPower 3400 (supposedly Keepower cells).
As anyone tried the Fenix 3400 and is it as good as their 2600?[/QUTE]
2600mAh batteries has higher voltage than 2900/3100/3400mAh batteries, in many single cell lights this is an advantage. This has nothing with brands to do, but depends on the chemicals inside the battery (High capacity batteries uses other chemicals than lower capacities).
Sorry for my lack of knowledge on this, but in the past I always have had better result with higher capacity batteries, obviously the result also did vary according to brand of batteries, and I kind of believed this was the reason why manufacturers keep bring higher capacity batteries. All the batteries are charged to 4.2v before start of test. Are you saying that 2600 batteries (if of good quality) are better suited to high drain lights?
And what is the advantage of using higher capacity batteries?
What application are the higher capacity better suited for? Maybe lower drain for longer?
I would like to understand a little more about your reply, thanks
