Can anyone tell me if the Opus BT-3100 v2.2 will charge the 16650 cells? I have one ordered (BT-3100 w/ 18650's), but after learning more about 16650's, I'd like to try a couple. Just wanted to know if I will need another charger, or if the BT-3100 will work. Thanks!
Hello. I have the Opus BT-C3400 and I can tell you that you can charge the Keeppower 16650 BUT it will only charge it to 4.2v.
The 16650 can take up to 4.35v so I use my Xtar VP2 and set it for 3.8v charging which cuts off at 4.35v. I love my Xtar VP2 because it can charge my 3.0v LifePO4 cells (3.6v cutoff), 3.6v (4.2v cutoff) and 3.8v (4.35v cutoff) cells.
I have the 2500mah Keeppower 16650 cells and tested them with the Opus BT-C3400 and it's a bit disappointing. It's around 2000-2100 mah. But that may be due to the fact it's charging to 3.6v specs (4.2v cutoff) and not the 3.8v (4.35v cutoff)? That's my guess.
The Opus charger is awesome and I chose that over the others (Maha, LaCrosse, etc) because it can charge Ni-MH, Li-Ion, LifePO4 AND when it's done charging... It does a trickle maintenance charge( around 24-34ma) on Ni-MH batteries to keep it full unlike others that cut off and the battery can self discharge sitting in the charger.
The Keeppower does have protection circuit however and it seems to only want to charge to around 4.30v before it kicks in and cuts off the charger. So it misses the mark by .05v.
