ven
A update around 10 months (December) a spring snapped on one of the bays. Fixed this, then another went, then another. The springs are very thin where they bend through the slider. Fitting longer cells must have put a strain over time(20700). I contacted the seller, sent a few pics of said snapped springs and received a new charger. The actual slide design looks a little different on the new c4-12, but without opening it, looks to be similar type springs(was hoping to be beefed up a little).
Only time will tell, offered to return charger but no need. So bought a spring kit off amazon and fitted beefier springs. Had to snip the ring end(one ring kept for the post, other opened up to feed through the slide neg pole.)
More resistance now , so have to be careful not to take the posts out! Other than weak springs, this charger has been nothing short of excellent. Most cells right now being charged are 26650's, voltage around 3.4 when placed on charge(Vape mod). Rate varies a little, 1.5 to 2.5a. The vtc6 and other higher drains can be up to 3a. It does pick a low rate for 16340 cells, usually 0.15 or a little higher. Still it's rare that a cell is on charge for much over an hour(not actually timed though). Of course you can manually over ride easy enough, press and hold and select rate. I have to do this with eneloop AA especially, as these get around 0.3a selected. Max is 1a for nimh, that's fine for me and that's what gets selected.
