Test/review of Vapcell INR18650 3400mAh F34 (Green) 2021
HKJ
Copenhagen, Denmark
[size=+3]Vapcell INR18650 3400mAh F34 (Green) 2021[/size]
Official specifications:
  • Min capacity: 3300mAh (0.2C discharge)
  • Nominal voltage: 3.60V
  • Max Continuous Discharge Current: 10A
  • Max Discharge Current: 20A
  • End-of-charge voltage: 4.20V
  • End-of-discharge Voltage: 2.5V
  • Weight: 48g ( Appr)
  • Internal resistance: 24mOhm ( Appr) AC 1kHz
  • Standard Charge: 1000mA,CCCV 100mA cut-off
  • Quick Charge Current: 2000mA
This is a high capacity 18650 cell with moderate current capability.
The two cells tracks nicely, they can deliver up to 10A, above there is heat problems.
[size=+3]Conclusion[/size]
The cells works nicely, but the internal resistance increases more than usual when the cell is near empty.
[size=+3]Notes and links[/size]
The batteries was supplied by Vapcell for review.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
