Great work. I suggest using 3 slightly smaller bolts than the two you have for mounting and adjusting the back/retro reflector. That will reinforce it against forces in all direction with less noticeable obstruction from the bolts. It will also allow you to adjust all three XYZ dimensions.
Thank you for the kind words.
I have to admit, I was going to use three smaller bolts, but my budget, and optional hardware for this project is running out, so I went with what I already had on hand. The good news, I was able to make 'slots' on the two adjustable plates that hold the whole assembly; so 'some' X,Y,Z -3 axis control is available. I also decided to line up the bolts with the hardware inside the bulb. I was surprised at how the bulb interior is not centered to the outer part of the bulb, so I added a slight 'twist' to the assembly to minimize all the shadows into just the two standard ones on opposite sides of the bulb. I have carefully measured the focal point using a bright 'point' LED lamp and am making sure the first start position of the arc is exactly where this is, (or should be), so I hopefully won't have to do much focusing.
Hope this works. Next one will be the 'delta' design as you mentioned.
I already 'bumped' the side of the assembly and wished that I had secured it with three bolts. I may use bailing wire for a temp fix...LOL. As you can see I have already resorted to some 'jury rigging' of things; out of impatience and a desire to get this searchlight ready for our CPF Seattle Area Get-together this coming Saturday, 26th day of May, 2012.
Hopefully I won't be too embarrassed. If the light beam is roughly the same or better than the 36 inch Gorilla, I will have accomplished my goal for this particular project of making a much lighter weight, and smaller, easier to transport searchlight. The Gorilla on the outside actually measures close to 40 inches, the 36 inches being the actual reflector surface size. The Gorilla can be a bit of a hassle, sometimes, to get into my care...still not too bad. The 30 inch Night-Hawk is the outside dimension of the reflector and the actual reflector with integrated frame is 29 inches. Overall, it is much easier to transport just being smaller and lighter-weight .
