No, I wasn't suggesting that low beams substitute for highs. I use highs, and more, whenever conditions/traffic allow. When approaching vehicles can be seen at 5km it's courteous to drop to low beam and that means a long time before passing.
You dip your beams when oncoming traffic is 5 kilometers away? That's about 25x sooner than you really need to by law; but I can certainly grant dipping them a little sooner.
Having good low beams is critical, as is having them aimed as high as is permitted. Generally I find that I can comfortably see out to the limit of the lit area but 90m is no substitute for 900m and being able to light up both sides of the road.
Having enough light to see that well nearly a kilometer away possibly means too much foreground light. Yes, we all like to see farther at night, but nighttime driving calls for different tactics from just having flamethrowers on the front. As you undoubtably know, many animals travel at night as in desert areas it's much cooler. I know that on my car there can never be enough light after a certain speed, because of the braking performance of the vehicle, reaction time, and such.
I'm not sure how accurate website "Car Stopping Distance Calculators" are, but I found one that was interesting.
From 80km/h (50mph):
Thinking distance: 15 meters (49 feet). Braking distance: 38 meters (123 feet). Total stopping distance: 53 meters (172 feet).
From 90km/h: 17, 48, 64. (56mph: 55, 156, 211)
From 100km/h: 19, 59, 77. (62mph: 61, 193, 254)
From 110km/h: 21, 71, 92. (68mph: 67, 233, 301)
From 120km/h: 22, 85, 107 (75mph: 73, 278, 351)
The reaction time is linear; the actual braking distance is proportional to the square of the speed.
In a standard sedan/wagon I still like to have the low beams out to a similar distance. It's not easy to aim them at that distance but I have a headlight aimer in the shop so no problem to get them accurate. The ECE standard does allow 1.0-1.5% declination in initial aiming and a limit as low as 0.5% with the horizontal part of the beam on the road between 50m and 100m so I'm towards the outer limit but still within the standard. A nice, comfortable place to be, IMO.
The range of declination below the optical axis is based on the headlamp height, under ADR (if I'm reading
this correctly. Yes, I know that's for the Northern Territory; I've been looking for a similar thing in the ACT, but haven't, yet).
I'd be very concerned driving a vehicle which had, as Alaric suggested, lights which gave only 2 seconds range and an effective speed limit of around 70km/h. Is there not room within the DOT/SAE aiming standards to wind them up a little more?
One can only aim them up so high until glare becomes a problem for other traffic.
Pretty sharp-looking vehicle. I see you've got an intake snorkel-- did you also snorkel the exhaust? My brother told me about a guy showing off his Suburban's new snorkel by driving in deep water, and the water pressure plugged the exhaust. Oops
Also, not to pick on you about your Lightfarce lamps, but you do plan on replacing them with something better eventually, right?
