Re: "The Torch"
Power to the lamp is supplied in the standard way. I have a USL stlye Bi-Pin holder modified with a G10 pcb which makes contact to the battery holder positive. The Halogen sockets I have sourced will accept all stlyle bi-pin lamps. The power is switched via the ground path through the tailswitch.
Mac
andrewwynn said:Hey mac.. how do you connect power to the lamp? is there a way to fit in a driver? this would be a killer light to add in a driver and run the 64610 or the 62138.. the batts you have in there would compete head-on with the CBP 1650s, and probably hold voltage better to boot.
-awr
Mac
