Black Rose
At our local CPF meets, computernut's L1s are always the most tested Surefires at the meet.
This thread inspired me to get an L1. How can you tell if the model is the older "low low" or the new 10 lumen low model? (Besides using the light) Thanks!
Ninemm, if the light has the shorter body it's almost definitely the 10 lumen low model.
Wade... I run a li-ion in my L1 as well... thinking, as you do, that if it does go poof , it will be great for something custom.
It seems quite content with a li-ion, but I must admit that I don't use it a lot.
AOW... you and Kestrel must be the L1 kings of the world! Isn't it great to find a light that you just love so much. Just one of life's wonderful pleasures.
Hey there, :wave:Here's what I was able to gather after MUCH research...will try to get some more info to fill in the gaps, but if anyone knows off the top of there heads, please chime in.
3rd Gen: Square Body/Hexgonal Bezel/Domed Optics (unsure)/Lux I driven at 1 watt (?)
-Hi: 15lm/5hrs
-Lo: .7lm/50hrs
5th Gen: Round Body (Longer than 6th Gen), Round Bezel (Shorter than Gen 6 Bezel); Last Gen to offer the Domed TIR Lens. Lux III driven at 1.2 watts for more efficiency
-Hi: 22lm/4hrs
-Lo: 1.1lm/90hrs
From this thread:Gen3: Like gen2 but emitter is Luxeon high dome. Note that optic is still NX05.
So it sounds like the Gen3 still had the oldest-style optic and a SF-spec 2hr runtime on high."The L1 LumaMax features a new single-die 3 watt Luxeon LED driven at 1 watt while the L2 LumaMax employs a four-die 5 watt Luxeon LED. The L1's light output is 0.7 lumens at low (50 hours) and 15 lumens at high (2 hours) [...]
The above info was kindly provided by another board member, and comes from the 2005 catalogue. Therefore it appears (to me) that not all L1's with TIR optic were created equal. (The current model is 1.1 lumens low @ 90 hours and 22 lumens high).
1st Gen: Reflector Based (The Real "Lumamax"; Had E-Series Styled Bezel with grooves about mid-way up). 1 Watt Luxeon driven at 1 Watt.
2nd Gen: Same as gen 1, but with a newer bezel (ala Mini-Aviator style)
3rd Gen: Square Body/Round KL style bezel replaces Aviator Style Bezel/Domed Optics/Lux 3 driven at 1 watt
4th Gen: Essentially a 3rd Gen Body with a 5th Gen Head
This L1 was the transition point to the newer looking L1 that we're familiar with
This is by no means an exhaustive list... and I don't have photos, sorry... but here's a start!
SureFire L1 Evolution
Gen1: Body has four flats. Head is short and tapered. Lens is flat. Bezel is plain (NOT scalloped). Optic is NX05. Emitter is Luxeon low dome.
Gen2: Like gen1 but bezel is scalloped. I believe some of these came with the SureFire lanyard and attachment in the box. Somewhere along the way the box style changed from cardboard box with lid to cardboard one-piece box with top and bottom flats, internal plastic tray, and clear plastic window through which the L1 is visible.
Gen4: Head switched to larger, KL4-like head with TIR optic, domed lens, and Luxeon (III?) emitter. Body is still the four flats version. These seem to be relatively rare! Probably a short production run before switching to the newer, rounded body.
Gen5: Like gen4 but body is rounded (no flats).
Gen6: (shown at SHOT 2007) Body seems to be 25% shorter than gen5. Head seems to be a little shorter than gen5 head, with emitter switched to Cree XR-E and optic switched to something similar in appearance to a Fraen LP optic... it appears to have a hole in the center that goes all the way through, although that may not in fact be the case (looked like it did to me, but Size15s reports not)... one can look directly at the emitter dome through this apparent hole.
Some photos to go with some of the above...
Gen1 Box Front
Gen1 Box Back
Gen1 Box Inside
Gen1 Flashlight
Gen1 Angled with NX05 Optic Visible
Gen1 Look Into NX05 Optic
Closeup of 4-Flats Body (Gen1-Gen4)
Gen3 Flashlight
Milky L1 (Gen3 Host)
Milky L1 SEOULmated, Look Into Head (Gen3 Host)
Gen4 Flashlight
Gen5 Box Front
Gen5 Box Back
Gen5 Flashlight with Included Lanyard
Gen5 Look Into TIR Optic
Gen5 Closeup on Domed Lens
Here's a photo I'd snapped recently of various L1 bodies, along with a couple friends...
Note the gen6 (L1 Cree, #5) host and how it relates sizewise to its peers: it's essentially the same length as the gen1 host (#4), and markedly shorter than the gen5 host (#3).
