Meh, I thought it runs at 830 lumen with 2 CR123 or an 18650. There are other lights as well with similar brightness using 3 or 4 cells.
Anyway, how does it perform with 2 RCR123s?
Is this light a good choice for my police duty belt....is it durable???
I think it is - in the short version ( with 1*18650/2* cr123) is great for your belt. Gives plenty of light, you can easily switch from mode, not to heavy,Is this light a good choice for my police duty belt....is it durable???
It noticeably out performs my Eagletac T20C2 mkii XM-L T6, which is rated 580 ANSI. I'd wager the TN11 on a single 18650 is still 700+ lumens OTF, easy.
gonna try that tomorrow thanksI took the tailcap off then took off the ring on it. After that you can slide the clip down on it with a little effort. Screw the ring back down after its on and you should be set.
