Tim B
I made a label for mine that shows the number of lumens for each click of the control ring. I printed it on a shipping label and cut it into a thin strip to fit in the proper place on the light.
Got my TN30 on Wednesday, Return to Battery Junction Thursday, On level 6 got a little pause flack, Also level 5 and 6 it seen as same output, Call the customer service to get RAM#, They said they will refund the post cost to ship it back, It is 14.60, they will check it to replace the new TN30.
Do any one here have problem like that? I had try the ceiling bounce, It's much brighter than my TK35, but on outside is about 2 times brighter than my TK35, But the Hotspot is not too much brighter, I like the flood but I need more throw.
:welcome: Yes, that is the presumed explanation for the soft start on high-output lights like this. A sensible precaution, to ensure good battery performance.
Hard to say without more information (i.e., trying the first batteries in another light, trying another set of batteries in the first light). As a general rule, "flickering" is more likely to be flashlight circuit related, but it's hard to say from this example.Its that a defected TN30 or the Eagletac battery overload protection cut out on L6?
Hard to say - I'd recommend you contact Thrunite directly if you have any concerns of authenticity. Asian manufacturers sometimes produce slightly different versions (especially of the packaging) for their domestic markets. Purchasing from an Asian distributor may thus have netted you slightly different stock. But again, contact Thrunite to confirm.i got both tn30(from hke for $220) and tn31(from thrunite store promo inc t10 for only $139,lost $51 on tn30).my only worry is that tn30 came in a smaller box,it does not have soft ramp at max,and the battery carrier has a copper coloured top,also warranty card is only paper,while the tn31 came with a credit card like warranty card,and the official box in the reviews.is this normal?
how does the TN30 compare to the Eagletac M3C4 XM-L. they have about the same lux and i cant decide which to get; M3C4 is a good compact thrower, TN30 lights up everything for a little more size.
Actually, the TN30 is more than three times the lumens of the M3C4 XM-L.tn30 blows it away with more then twice the lumens
Any LED light have good throw and flood for AR shooting around 300 to 400 yard? I'm using EagleTac 3100mah 18650.
