VNguyen
- Joined
- Jan 2, 2016
- Messages
- 494
The 30q are button top but are shorter than other button tops like LGmj1. Good idea but knowing my clumsy hands I might melt the spring down lol.
Hey buddy how you been? How is your tm16gtvn q70?The 30q are button top but are shorter than other button tops like LGmj1. Good idea but knowing my clumsy hands I might melt the spring down lol.
Good idea, though 2 springs are inside of the tube.
You could still add solder onto the two brass contacts on the tailcap and get the same result.
I don't think you'd have an issue with damaging any springs unless you purposely overheated the springs and compressed them. I've done this on lights with much dinkier springs and had no problems even with a very powerful soldering iron.
I use magnets on my flat tops when a button top is required. That adds 2-3 mm of length.
Look on eBay for Neodymium magnets 5x2 mm. The cost practically nothing so get lots of them. They are 5mm diameter disks, 2mm thick and very strong.Can u send me link where to get those magnet? I want to try them out mad.
There are 2 springs on the top side also which will give me problem getting solder to them.
... If the magnet slid off center and shorted to the side (like if the heat shrink insulation was damaged) it would short out the battery which is dangerous. It is still common practice to use magnets but like I said I'm very paranoid about Murphys law.
Yes I have seen the inside of one. Two springs and two brass buttons on the tail cap. You can add a blob of solder onto the springs and brass buttons on the tail cap to make up the gap with flat tops. Magnets will work too however I do not like magnets because I'm paranoid. If the magnet slid off center and shorted to the side (like if the heat shrink insulation was damaged) it would short out the battery which is dangerous. It is still common practice to use magnets but like I said I'm very paranoid about Murphys law.
My modded GT runs good with 30Q button tops.
Will it run flat tops now?
@VNguyen DON'T mix cells! Use the same brand & model number purchased together. Then always use that set of cells together.
I label all my cells with a silver or black Sharpie marker. I write the name of the light and 1/4, 2/4, 3/4, 4/4 on the cell.
I have three battery chargers and it's easy to get confused when the cells are outside the flashlights, on the chargers.
