OrcaTorch
Banned
- Joined
- Apr 23, 2014
- Messages
- 7
:kiss::kiss::kiss: [FONT="]ORCATORCH D500+ is a portable magnetic controlled flashlight for professional diving use. It is equipped with a totally sealed
magnetic controlled side switch that provides flexible operation underwater. Using the latest USA CREE XM-L2(U4) LED, max 1000
lumens output and over 18 hours runtime, this portable diving light offers three brightness levels and one strobe mode for diff-
erent diving enviroment use. Plus simple style appearance, robust water pressure resistant construction, we believe it will be your
best lighting tool for diving. [/FONT]
Products Features:
* Cree XM-L2(U4) LED, max 1000 lumens output
* Uses 1*18650/2*CR123A/2*16340 Li-ion battery
* Aircraft-grade high strength aluminum material
* Alloy aluminum reflector with professional optical analysis
* Magnetic controlled side switch, high waterproofness for easy operation underwater
* High efficiency constant current circuit, constant brightness
* Reverse polarity protection, to protect from improper battery installation
* Premium Type III military hard-anodized seawater-corrosion-resistance finish
* Toughened glass with high water pressure resistance under deep water
* Water pressure resistant construction, depth rated to 150 meters
* Standard included wrist strap fastens the flashlight to the back of your hand
Products Features:
