Hello and Seasons Greetings to all.
Looking for info and thread links on wiring Triple LED (probably XP-G2)
How To's, Differences, Pros and Cons of wiring in Series or Parallel.
Thanks
Hey, check out the Noctigon copper triple MCPCB. It allows users to choose either series or parallel, just by soldering 2 points.
And both sets requires just 2 wires, instead of the 6 wires if u go series.
I have so far used parallel setup only so i can't comment much.
But these are the few considerations i had.
Driver choice, i can use the AMC7135 drivers & also 1 lit-ion only.
Emitters, i have to buy them in a reel because the Vin of the emitters will be closer to each other. If their Vin readings are quite big, you will have. problems.
No worries if one emitter fail, the other 2 will still work but more current will go thru them.
Parallel, shared current from source.
If driver is 3A, each emitter will get 1A.
So with AMC7135 drivers, i can stack the chips to increase my current output.
- JonK
