Dark Blue? See my response above. Four hours sleep, total darkness, and I barely see the blue tube six feet away. Very dim glow. The green tube half it's height and thickness (aka 1/4 of the blue tube's size) set in a flashlight) is FAR brighter and is easily seen. The green tube the same size as the blue some ten feet away is also easily spotted despite the fact it points at me so I get only the end... But the blue is laying in the desk and shows most of it's length.
That's how much of a difference there is between dark blue and green. Ice blues aren't nearly as bad.
Thanks, this gives me a better idea about the blue.
I just wasn't sure if it was visible unless it was within a few feet with a lot of people saying it was so dim.
I have good vision so it shouldn't be a problem.
If there's any ambient light, that 2 meters is going to get cut in half easily. When I first got this set of red, dark blue, and green, I set all the tubes down on the desk and waited a half hour in the dark to test it - the green was very visible even with some light leaking through the blinds of my suite. The red was dim enough that I had to approach the desk a bit to see it. The blue was worse - the bits of light from outside and the other tubes drowned it out, and I had to be right beside the tube, and even then it barely showed.
Green, white, ice blue, and yellow are the best choices for use - the rest are there to look pretty, and maybe provoke conversation. Not for use, unless you've got an ELCAN scope or some other sight where the light isn't bring used to mark something to catch your eye.
