The_Police
Wow nice looking upgrades.
Do you mind if I ask a couple of Q's?
1. The mode switching, does it switch modes every time you turn it on, or does it reset after a while? e.g. if you leave it in low and go back 30 mins later, what mode would it turn on in?
2. I'm fairly new to this modding lark, if I wanted to do something like this what would I need? I'm guessing the drop in, something to cut the drop in down to fit and then simply solder on the wires from the switch, or do I need some sort of control/driver board too? I suppose related to this, is the drop in being direct driven or regulated.
3. Are you still running regular alkaline D cells or something else?
Thanks ever so.
Thanks, and I'd be glad to answer your questions!
1. The modes always stay the same after it is turned off. So if I have it on the brightest mode, turn it off. Then come back to it whenever and turn it on, it will still be on the brightest mode. I also posted a video up a ways in this same thread that went over the mode switching. Not sure if you watched it yet, but if you haven't, it may answer these questions as well.
2. First off, yes you need this (or similar model) drop-in from DX, and it comes with the 5-mode driver installed. As far as fitting the drop-in in the head, It will fit in the head as is, but the bezel of the mag does not thread on all the way (that looks bad to me) and the head also will not screw down all the way because the drop-in will hit on the battery tube of the light. (that's why I machined mine to fit inside the battery tube) You can use a grind wheel for these tasks, but I recommend using a turning lathe if you have access to one.
-Then you can use a hacksaw, dremel with cutting wheel, or a turning lathe to remove the lamp post from the switch assembly.
-Two wires (about 5 inches long is more than enough)
-Soldering iron and solder (be careful about how long you hold the soldering iron on the driver to remove the contact springs! I already burned one up on accident)
3. Yes, I am using four Duracell "D" batteries in the 4D, and six Energizer "AA"s in the red 2D (I prefer Duracells, but I only had energizers at the time I needed batteries)
I hope that answers all of your questions, and as always, feel free to ask any others you may have.
