if you analyze the waveform on oscilloscope at the gadget charger terminal, for example mobile phone itself, you will notice the charging algorithm is not simple as CC/CV only.
at first some pulse at varied time interval would be fed into cell for probing cell voltage and remaining capacity, then only CPU/MPU/MCU would select the proper charging current in terms of pulse width of PWM to begin the charge.
during charging process the circuit continues to monitor the feedback at each PWM off period to determine current charge state and adjust the pulse width accordingly all over the time, resulting in variable output voltage and current.
when the feedback cell voltage raises up to around 4.15v output current will drop exponentially and continue to charge and monitor until it reaches perfectly at 4.20v (+- 0.01v)
for any other NON-OEM 2 bay chargers, the best algorithm seem to be charge - probe - charge - probe at fixed time interval, on the other hand the output voltage being fed into cell is fixed until cell reaches 4.2v, and only Pila IBC manage to terminate perfectly.
advance algorithm are applied on high end hobby charger, laptop and almost all mobile phones, even on the cheapest $25 Nokia.
only OEM design from reputable brands offer the best quality of cell and charger, they are well researched and developed to avoid costly lawsuit and massive product recall (billions compared to less than few thousand units sold in flashaholic market), due to the fact li-ion cells are not meant for direct application for consumer, i am dare to say all 2 bay chargers in the market don't meet international standard of testing and regulation, prove me wrong if you can find one with real UL, CE, TÜV, FCC certification.
imagine if you burnt down your house, whom are you going to sue ? you probably won't even be able to find out who is the real manufacturer, even if you found out do you think they have the money or insurance to compensate your loss ? all community product in this market are maybe just higher than hobby grade, but it will never meet the OEM standard.
i am not advising anyone to modify gadget chargers unless you know exactly what you are doing.
for plug-n-play Pila IBC as 2 bay charger, Schulze as hobby charger and AW as protected cell are the best you can get in market, but when a cell is slowly venting inside a flashlight, no matter how many safety features it has, which including thermal, over current, self strip-off contact due to cell pressure, safely release valve on cell..etc, the light will still blow up violently because the air tight chamber really does not have much room for the vented gas, unless flashlight also implement a safety release valve or burst disc.
conclusion, use the best components and products available to keep the potential risk at the minimal level.
