Under cabinet Dilemma
coreyhudson2
Hey Guys,
Ive been given a task to light up underneath our cabinet (w/Led) for less than $150
Few Requirements:
Warm White needed
Combined 2000lm over a 15ft span
Few ideas:
2x Xitaniums 700 + 5 Bridgelux 440's (Too hot)
2x Xitaniums + 11 XPG's (Expensive)
2x Xitaniums + 11 XPE's (too dim)
5x Halogen Strips (300w + Expensive!)
Anyone know where i can get decent WW (or Equivalent) LED's, and what you recommend to power them?? Preferably >120lm per
!lovecpf
jason 77
cali
Hey Guys,
Few Requirements:
Warm White needed
Few ideas:
!lovecpf
5 bridgelux 440's would be extremely bright for under cabinet lighting!.. how bright does the light need to be?
blasterman
Bridgelux makes a 240'series emitter that throws 265 lumens / warm-white. Newark sells them for $5.20 each. This will allow you to spread your light around better than 440's, which as you've mentioned present thermal management challenges in confined spaces.
Also, look at Mean Well power supplies along side Xitanium. When it comes to higher currrent and voltage levels Mean Wells are quite a bit cheaper.
Personally, unless I requires bright islands of light in specific areas, I'd do this with commercial SMD strips. Good ones - not the junk you find at Home Depot, Lowes, etc.
arek98
New Jersey, USA
Hi
Some time ago i build lights for my kitchen (I started buying parts probably about 2 years ago). I bought 25 Seoul 889-N42180L-S2 LEDs (3000K, 93 CRI) and was thinking about driving with CCHIPPO from TaskLed but I was uneasy about having two strings and (I figured I need about 18 LED's for my kitchen, keep in mind that these Seouls are not very bright comparing to XP-G or other LED's available today).
Time passed by and TaskLed released hyperBoost and that was something that could handle my LED's as one string. I bought one and finally finished lights and they work great, including dimming with pot (anding up with 17 LEDs in single string).
However, I needed power supply for hyperBoost, I was thinking about using old laptop AC adapter because I couldn't find any PSU in reasonable price with required wattage and then I found this
I purchased 60W, 24V constant voltage one but they have models specifically for driving LEDs (constant current), even with dimming support (I don't use my much) in $30-$40 price range. Look at this one
It should be perfect for driving up to 12-14 LEDs (maybe even more if they are low Vf).
The hardest part was to mount them (I don't have access to machining shop or something). I used 6" wide and ¼" thick aluminum bars and some polycarbonate to shield LED's from whatever may happen in kitchen J. Aluminum was an overkill, but I did not count area under polycarbonate as heat sink and I didn't want cabinet get warm (at id does not, lights can run all day and aluminum still fills cooler than hand when touching).
coreyhudson2
Good lord... 700ma driver an 11 XPE's are too dim?
Whats the purpose?!
Lol, i just guesstimated a 57W bulb at 700 Lumen's for a 10 foot strip of counter.
But a WW XPE is ~57-90 (@350ma) Lumens at $7, thats where i came up with the 11 is too dim.
mds82
Connecticut
I just did my cabinets....
I ran 12v to all of the cabinets first
used 1 BuckToot driver and used 2-3 Cree MX-6's per cabinet. I ended up needing about 7 units total.
I think it all looks great. I am going to try and get some pictures
coreyhudson2
Cant wait to see them!
Thanks all you guys!! I figured on running a 5050 Led strip from dealextreme to and old server PSU. And instead i will use some bridgelux to retrofit our front light since it gets too cold for CFL.
Again THANKS.lovecpf
Illum
Central Florida, USA
how low is the cabinet you have in mind for this installation? I ask because different types of LEDs have different emission angles, some of the wider varieties allows you to space them out father apart without losing the intensity in between. This would be something to consider if you are looking into reducing your LED count.
planning a build can be fun because it gives you the opportunity to explore diferent choices. A good thing with modern day CREEs is the ability to drive it at an amp, IIRC Xitaniums 1045ma offline driver [LED120A0024V10D] has dimming capability. Depending on your needs you can dim your LEDs to a low state until you need to use it, then ramp it up. this should alleviate at minimum some of your heatsinking woes.
