JCD
- Joined
- Apr 12, 2010
- Messages
- 892
The TWOFISH Cycloblocks lave longer, heavier duty straps which might be plenty long enough to work. One could also try mounting the lockblock or Cycloblocks on the stem itself.
??? It's not a matter of the strap fitting around the bar. The blocks themselves are molded for smaller bars. I've already found more secure solutions that can be made to work. I'm looking for a secure solution that doesn't require any work-arounds to meet my needs.
The stem is not horizontal, so adjustment on another axis would still be required.
I cannot really address a bias unfounded in fact or personal experience...velco is very strong and reliable but, like ALL things that are used regularly, a little preventative maintenace likely goes a long way. Even if it were a screw/threaded solution you'd still need to tighten the screws on occasion.
I have plenty of experience with Velcro, and the fact is that it wears out, and as it wears, its bond progressively weakens. With a threaded solution, it is simply a matter of tightening a nut/bolt. With Velcro, proper preventative maintenance is periodic replacement.
