Photoluminescent vs. Tritium
One could think, if tritium has this disadvantage, why use it? There's different reasons. Photoluminescent and Tritium are the two types of non-electrical
exit signs that are available on the market today. Non-electrical photoluminescent and tritium powered exit signs have gained popularity since they were introduced for a number of reasons.
Non-electrical exit signs are favored over electrical exit signs:
1. From a new construction standpoint, they eliminate the time, labor, and
supply costs of running a dedicated emergency circuit for exit signs.
2. From a retrofit construction standpoint, they eliminate the invasive and
expensive cost of hiring an electrician for installation.
3. From a maintenance standpoint, there are no wires, batteries, or movable
components to maintain.
4. Because they can last 20 or more years, whereas LED exit signs last 8 to
10 years.
5. Because they can help attain LEED points which work toward the USGBC
LEED Certification Program.
Non-electrical exit signs are tested and certified to the same standard (UL 924)
as electrical exit signs. Carrying the UL 924 Listing means that non-electrical exit
signs can be used in the same applications as conventional electrical exit fixtures
with no additional approvals needed. The non-electrical exit signs that we carry
are UL 924 Listed for both the United States and Canada.
Photoluminescent exit signs use industrial grade glow-in-the-dark pigment to illuminate in dark conditions. While the lights are on, the supercharged photoluminescent pigment charges itself by absorbing light. When dark conditions are present the sign will glow for a minimum 90 minutes. Photoluminescent exit signs have a 20-year lifespan as long as the face of the sign is kept clean. They are offered with viewing distances
of 50, 75, and 100 feet. Photoluminescent exit signs are suitable for indoor
applications in commercial facilities where the lights are on while the building is occupied.
Tritium exit signs use tritium gas, an isotope of hydrogen, to self-illuminate. Tritium gas is inserted into shatterproof glass tubes that are coated in a phosphor.
When the tubes are sealed, the tritium interacts with the phosphor and produces a green glow that requires no outside power source or light for illumination. Self- luminous tritium powered exit signs are available in 10 and 20 year service lives. Self-luminous exit signs are available with viewing distances of 100 and 125 feet.
Self-luminous tritium powered exit signs are suitable for indoor and outdoor
locations, including extreme environments and hazardous locations.
