If I was doing this for myself...
I would use the Bridgelux BXRA-40E7500-J-00 (4000K, 80CRI ($63.83 from my favorite supplier)
8250 REAL (actual in sustained use) lumen at 3.2A 30.5 that equates to 84.5 lumen/watt During sustained use.
or the Bridgelux BXRA-50C9000-J-00 (5000K, 70CRI ($76.65)
9416 REAL (actual in sustained use) lumen at 3.2A 30.5 that equates to 96.5 lumen/watt During sustained use.
use one TASKLED Hyperbuck @ $40
Don't bother with any kind of reflector (if you are wanting to use it at 15' or less and you want it to cover a large area... you don't really need it.
This gives the simplicity of a single large LED/ single driver setup, that can be driven by something as simple as 3 small 12v SLABs or as exotic as a 11-12cell Li-ion setup... For a setup with 12 (panasonic ncr-18650a) li-ion cells, it would weigh 19oz and run for a little over an hour or so (I figure about an hour and 5 min) or 3 7.2AH 12 SLABs (at a weight of 14lbs and figure maybe 3-4lbs for the heatsink (can be fairly small) and everything else... As long as the enclosure is greater than a 7.82" cube ( 476.76 cubic inches) it will be buoyant (so you could have more space for battery as ballast)...
So
$77 for LED
$40 for driver
$81 for SLABs
$5-10 for heatsink big enough for water cooling the LED
$30? for enclosure...
$20 for switches and wiring
So about $258 for the whole thing (give or take $20-30
But that's just me...
Oh, and run time on the SLAB setup is about 100min...
So
$77 for LED
$40 for driver
$81 for SLABs
