I use the AW 16340 in all 3 of my HDS lights and am very happy with them, they are 750 mAh.
More like 500-550mAH per HJK's testing. I would just go with Efest 550mAH IMRs. They are cheaper, easier to find, can produce higher current, and are rated quite truthfully as far as capacity.
Thanks, but not interested in unprotected batteries.
Re the tests on AW's -- can that be true? Do you have a link to the test?
http://www.candlepowerforums.com/vb...Test-Review-of-AW-16340-ICR123-750mAh-(Black)
Bear in mind that RCR123a batteries are notorious for overly optimistic capacity ratings. I'm actually surprised that HJK gave this battery a 'good' rating despite the fact that its actual capacity falls a whole 200mAH (26.7%!) short of its rated capacity.
Speaking of protected vs unprotected, does the light not have overdischarge protection?
For the record, I've used AWs and EagleTacs and haven't been overly impressed with either.
Has anyone found something better?
In what way aren't you impressed with them? For normal flashlights all I can think of is runtime and since AW and eagletac are both solid brands i'm not sure you can improve much on batteries.
I'm guessing the fact that capacity is well below the stated amount and the correspondingly short runtime. This is a problem with virtually all RCRs. As far as improving on the batteries, this is VERY possible - if someone actually had the desire to do it. Sanyo/Panasonic currently sells a 2500mAH 16650. Given that this is a 4.35V battery, the capacity at 4.2V is probably more like 2200mAH. But since a 16340 is at least half the size of a 16650, there is no reason why we couldn't have a REAL 1000mAH (at least) 16340.
Well said.
The runtimes do indeed seem short.
If you want longer runtimes, use your 18650 lights.
Chris
That's the problem. There aren't any GREAT RCRs out there. They're all fairly mediocre. ...
...which are the best -- that is, longest lasting -- protected 16340s.
The longest lasting protected 16340 battery at 2A load is the Keeppower 700mAh. The Efest 850mAh is a very close second place finisher.
http://www.dampfakkus.de/akku_auswahl.php
