Bump. So an Eneloop at an open resting voltage of 1.2 volts or lower should be recharged... correct? Also, I just checked some Eneloops I rotate in my lights (they only go in 2 cell lights and are marked and matched, charged properly, rotated, new cells, etc.). They were charged and stored properly about a month ago, or slightly longer. I tested them and 2 different, cheap voltmeters gave me readings of 1.27 and 1.29v on the same cell, so 1.28 average (I accept the slight variation between the cheap volt meters). I am assuming this is a normal voltage for the eneloops... just making sure. Cells were charged using a Powerex (maha)MH-C9000 after a 1000 ma charge.
