StorminMatt
I just had one of my 3 AAA White/green LED Lensers fail this week.
The battery carriers in their 3AAA lights are notoriously unreliable.
I come at this from a different angle, and maybe some of you can help me. I'm a professional photographer.
ckeilah - Ideally invest in some AA Sanyo eneloops , these will pay for them selves within a couple of charges and you will get the best out of your light.
There are two methods of controlling LED brightness in flashlights:Today, when I looked at the included MT10 through the lens of the digital apparatus,
I saw what I did not expect to see - PWM flicker.
This is cool, then the flashlight will keep a good brightness for a long time.
PWM - the LED is run at max power, but is strobed on and off to produce the effect of an intermediate mode or low mode.
PWM has the advantage that the tint stays the same at all power settings.
The downside is LEDs are more efficient when run at lower current. Since with PWM the LED is actually run at high current all the time, the net effect is runtime below max power will not be as long as light with current control.
Also if the PWM pulses too slowly it is visually noticeable and can be unpleasant to look at. For this reason slow PWM is generally conisdered to be the worst method of regulating lower modes in an LED flashlight. Fast PWM is PWM that pulses at a high enough rate to not be visually noticeable. It can look as smooth as current control, but without the tint shift or extra efficiency. If a light is using PWM always look for fast PWM
Current Control - the driver supplies less power to the LED in lower mods. This is the most efficient kind of LED light giving the longest runtimes at low power, but the tint may shift dramatically at lower power settings.
Bottom line: LED Lenser's use of slow PWM is a bad sign. It basically means the light is using the most dated and least effective method of regulating brightness in lower power settings.
Here I do not agree. It's not like slow PWM, since my eyes do not see flicker, I see flicker only through the camera lens.
The only place where I see a flickering with no-armed eyes - is my Surefire E1B and E2D,
but that does not make them bad lights.
