2xTrinity
This is the problem with integrated phosphor LEDs. The phosphors degrade over time, just like the phosphors on fluorescent tubes. The direct color-emitters don't have the same problem of dimming over time (at least not necessarily... LEDs that are overdriven or poorly heatsinked do). IMHO the street lights will be a much better bet if they use RGB rather than phosphor LEDs (the problem with that for the time being is that efficiency on the green component is terrible).yellow said:While they still are quite more eye-catching than the old incan version, the middle cluster is obviously dimmer than all the others around.
--> will happen to street lighting also
--> money burned for nothing within some years time, bureacracy on its best (if used instead of light tubes).
Hope they will do a test run with just a few lights be4 changing everything
The other option would be to design street light with SEPARATE phosphors and separate blue emitters. The phosphor could be built into the diffuser (which would make for more nicely diffused light -- important to cut down on glare), and it would be cheaper to replace a phosphor-panel than dropping in entire new LEDs every time. Even then though, the LEDs shuld be potted and easily swappable, similar to standard lamps, rather than the current design philosophy of engineered obsolescence where the entire fixture must be replaced if an LED dies.
But finally, to take full advantage of the LEDs, I think it would be wise to build in the ability to switch the street lights off and on using motion sensors -- that way, the lights would only be burning when someone is actually present (extending the life of the LED, reducing light pollution, and saving energy).
