benchmade_boy
Al- dont you think that they should have at least offerd me a modern day replacment? i meen at least a spares carrier or somthing in that matter.
benchmade_boy said:Al- dont you think that they should have at least offerd me a modern day replacment? i meen at least a spares carrier or somthing in that matter.
Size15's said:It's not that simple and there is an important difference worth noting.
The 6Z was superseded. The 6Z was replaced by the Z2. Additionally, if any component of the 6Z specifically requires replacement there is parts interchangeability with current models. The Lamp Assembly (P60) is the same. The TailCap is currently the Z41 LOTC although SureFire likely have non-LOTC in stock for those who use the Sxx tape pressure switch still.
The bezel is currently the Z44 with it's hexagonal anti-roll styling and Pyrex window although SureFire likely have stock of the Z17 Lexan Lens (window) replacement kit if that's all that is damaged.
The body can be replaced by the current Z2 body.
This is the case of most SureFire products - they have either been superseded or there is currently a similar model that can be offered as a replacement.
Much of SureFire's 'Classic' range is supported because it supports it's 'Classic' WeaponLight range for example. The 3V R30 Lamp Assembly is used by lots of old handgun WeaponLights and so users of the discontinued 3P can get replacements even though the 3P was replaced by the E1 and now the E1e.
The 12B is one of the exceptions where there is no current version, nor a similar product. There aren't very many similar exceptions. The "T" Series and T-62 TurboHeads (including the N62 lamp assembly I believe) have no direct replacement although there are modern versions. To purists they have no current equal.
Al
