LeanBurn- Details on the 2xAAA mod, please!
It is actually quite easy. Remove the reflector from the head and hold it in your hand. Holding it in your hand gives you the tactile feedback needed as it is small and fragile. Slowly step bore out the reflector from the bottom as to not break off any of the flanges that protrude from the reflector that rest on the edge of the switch mechanism. Step bore taking a bit each time with a bigger bit until the hole is big enough to accept the width of the bottom of the LED.
Then measure the wire legs of the incan lamp against the LED and trim the LED to match. You will have to bend the legs a bit inward as to have them be the same width apart as the incan legs were. Then plug the LED into the same holes as the incan did...if it does not light up reverse the legs. The LED should sit flush against the black switch mechanism. In summary the LED should mirror the way the incan bulb sat.
Re-assemble the reflector and put the head back on and...voila! You now have the same Minimag 2AAA with the same 9L output, but it uses the highest CRI LED available but now with much more durability and much more run time.
I would like to see how the different LED beam angles (65deg vs 45deg..or whatever) work with the reflector and if throw is altered if someone has both. I only have the 45deg.
