Ooh, more news, meaning the Seoul P7 is getting closer to be in our hands. Cool...
Now, What is the deal with Lumileds? I wonder why Lumileds doesn't release something similar, but either in the form of the LuxV package (or scaled up a bit), or in a larger ceramic substrate like the Rebel and Cree XR-E. Imagine a substrate, say 6mm X 6mm, with 4 TFFC dies bonded in the center, and connected in series with each other. When you look at the big picture of the Soul P7 in the above link, you will notice that they had a problem with the bond wires going to each die. The Seoul P4 uses two bond wires going to the top of the die, while the P7 uses only one each (to keep the bond wires from obstructing the light any further). With the TFFC technology, all electrical contacts are below the die (connected to the top of the die by multiple small vias), and there are not any obstructed views! Die placement can also be closer (if the power density is not a problem). You can then have a smaller package, a nicer beam (for the most part), and the package would only need a small glob of silicone to cover the dies that may be slightly larger than the normal Lumileds dome. Wires are soldered to the top or bottom on pads like the Cree XR-E and sort of like the Rebel, so fragile leads (like on the standard Lumileds Luexeon emitter and the Seoul P4) do not break off, which usually renders the emitter useless.
Does any one else wish for something similar? Maybe if Cree jumps on soon, Lumileds will feel pressured to update their multi-die emitters. With the above substrate, you could also increase the number of dies for increased brightness (considering the power consumption and power density is not too high). 3 X 3 dies would be wonderful, to compete with the nearly lethal OSRAM OSTAR. Lumileds can then compete in the market of forward automotive lighting, and also for light sources for projectors and rear-projection televisions. They can even spread out the dies to make it more suitable for fixed lighting. I guess a handful of Rebels could be used for fixed lighting
There I go: dreaming... and ranting. Why can a fellow's dream come true? It can be done now, and I bet that demand for such an emitter has to be high (if the awkward Seoul P4 is getting such a warm welcome), so why not try to release products like this? Come on, Lumileds! <sigh> :sigh:
-Tony
