Darell
Yikes! Didn't know what I'd started here. There were so many similar threads on this, that I lost track. Klaus was kind enough to nudge me back to finish what I started.
First off, back before I even posted in this thread, I sent PK the link here, just as a heads up. I'm pretty sure that he's aware of the score.
Second - what I did to my clickies involved complete disembowlment. The notched ring at the end (which is locktited into place) was removed, and all the guts spilled on the bench. I've heard reports of folks not being able to reassemble all the parts correctly after this proceedure, so I can't, in good conscience, recommend it to anybody. The one consistent correction that I made to each switch was the addition of Nye control lube to the plastic sleeve that rides up and down in a high-tolerance plastic cylider. Sometimes that sleeve binds up right when the switch hits the click resistance. This can cause that odd mushy feeling, and can also cause the switch to stick. The switches that required a thumb TIP press to operate before the procedure, all became operable with the ball of the thumb after the procedure. In none of them did I alter any springs. Some remain slightly harder to press than others, but they all have much better action and consistency.
This is an extrememly high-quality switch. And I don't say that lightly. This one is truly deserving of the Surefire name. A spot of extra lube in just the right place would have made it stellar.
