DavidMB
- Joined
- Jan 5, 2005
- Messages
- 112
I am curious to know what Selfbuilt thinks of the pocket clip with regard to the ridges.
....But I certainly don't feel any sort of offence to any of the comments I've seen - and I think it is important to raise and discuss these issues. Not sure of the best place for it, but I'm fine with leaving it in this thread (along as everyone stays respectful of everyone else).
I don't have much comment, except it may be a bit more cumbersome to slide it on to things than the SC51 (i.e., those ridges do restrict the smooth flow of material). I typical carry my EDC in a holster on my belt, and found the clip tricky to insert over the material in this case.I am curious to know what Selfbuilt thinks of the pocket clip with regard to the ridges.
Absolutely, it is a good point - beamshapes are a major factor in how you experience the light. This why I do all those standardized white-wall beamshots, to allow you to compare differing profiles. And as an aside, they are also a confound for lumen testing, as even a perfect sphere can never fully integrate all beamshapes consistently.I'm going to add my unsolicited two cents to the lumens debate here. As long as everyone's beamshapes are different, I really think all a lumens number does is get you in the ballpark. My 200 throwy lumens bear no resembelance to your 200 floody lumens which differ in appearance with your 200 lumens in a bigger/smaller reflector... Beamshape, (proper tool for the job) sufficient output for the task at hand, and efficiency (runtime) are what do it for me. Thank you for trying to keep things comparable for us, but there are a lot of variables, absolute lumen numbers are just one of many.
Good to know - thanks for sharing. The problem with only having one sample is that its hard to know how representational it may be. Interesting that you independently had the same observations for the low levels on yours.I know his relative data is good and consistent, and the despite claims of sample variability, I have found my relatively measurements to be very close to his, except that I chose to use a different scale. Adjusted for scale, I have previously come up with nearly the same SC52 measurements down to overspec'd L modes, and even the odd drop off on Li-ions for the L1 mode..
Yes, that would be interesting. And thanks for the donation plug, always appreciated. :wave:I'm really hoping now though that they hurry up with the SC62, and I hope that they also start using the Nichia 219 HCRI LED in versions of the 18650 and AA lights. I guess I better find your paypal 'donate' button.
i am still looking for SC52 owners who also own post 2011 Fenix models with comparable brightness because my reference scale is not selfbuilt or Zebralight but whatever Fenix claims. the other day i borrowed a brand new Fenix LD20 R5 from a friend and with 2x Eneloop AA the claimed 180 Fenix lumens blew away all of my 1xAA lights by 4sevens, Thrunite, Eagletac, Jetbeam .. by a huge margin. "180" is a comparatively low number nowadays and mev reported 199 lumens in his LD20 R4 review but the margin by which the Fenix wins over D25A, Quark X w/ 1xEneloop AA, a.o. is incredible. simply put, at this point i cannot imagine that the SC52 is brighter than the 2x Eneloop AA Fenix LD20 until several users do report it.
I certainly was not aware that a 1xAA light was in the same comparison category as a 2xAA light.I personally asked Selfbuilt to include onin the 2xAA graphs (which he did), and also the CR123 graphs (which he did not), since this light attempts to compete with the top of the class in those batteries categories.... ummm, on paper at least.
I agree, it is rather ironic to see a modern light perform so well on the rather archaic alkaline cell. I would certainly never want to store one in there, given their propensity for leaking.
That would be interesting ... although it may require a circuit re-design from the current SC52. Given that the SC52 currently reads a ~3.2V primary 14505 cell as nearly depleted 14500 Li-ion and automatically steps down, I expect it would also read the ~2.8V of 2xNiMH the same way. So an extension tube may be out, but no reason for them not to design a separate 2xAA ...I think this light needs and extension tube. Make it a 2 AA Zebralight !!!!
Well, generally it isn't - but it was close enough that I agreed to the request and added the 2xAA comparisons (with extra table, graphs, beamshots) into the review.I certainly was not aware that a 1xAA light was in the same comparison category as a 2xAA light.
I just tried this today, with a little help from the extension tube from an Ultrafire C3, some aluminium foil, brazenness and good luck. I too expected the circuit would interpret the two GP ReCyko NiMH gen 2 cells I used as a Li-Ion cell close to its cut-off voltage, but surprisingly, it stayed in high mode (turbo rather, it looked like ~500 lumen) for several seconds. I would probably have run out of luck if I had attempted to operate this precarious MacGyverism for too long, so I don't know if would have stayed in high for a full minute, or stepped down early.
Some time ago I posted in another thread a rendition of what a 2*AA Zebralight might look like (post#24)
http://www.candlepowerforums.com/vb/showthread.php?345627-***NEW***-Zebralight-SC32-%28single-CR123-light%29&p=4102662&highlight=#post4102662
I just violated the end of my SC52 with the battery tube from my Maratac AA. Selfbuilt was right as it did kick off. It would go through all the modes but when I let off the button it went out. MY SC51 on the other hand worked just fine.
Thanks for the confirmation, that's what I expected. Interesting that it worked on the SC51 ... that light was never intended to work with 14500 (although mine at least seems to handle them), so there's no low-voltage cut-out to be concerned with.I just violated the end of my SC52 with the battery tube from my Maratac AA. Selfbuilt was right as it did kick off. It would go through all the modes but when I let off the button it went out. MY SC51 on the other hand worked just fine.
What the comparisons show is that while the SC52 may approach the max output of some 2xAA lights, it cetainly can't handle it for long on a single standard cell (as expected).
...SC51 was the most efficient AA light on the market. So it looks strange when somebody tries to downplay its successor and potentially the new king of efficiency. Now we know that SC52 is the most efficient AA light on the market whatever the lumens are thanks to selfbuilt.
