NotEnoughLight
I recently got some potted 1185s from Sinjz and they arrived today (Thanks Sinjz! You :rock: ). The batteries finished charging up and i let them rest for 20 min or so before firing the bulb up. My setup was a 2D mag with 8AA NiMH with a MOP reflector. My first impression..
For a light this size, I am amazed by the amount of throw and lumens spilling forth by the mere touch of a button. IIRC the bulb lumen was 800+ which translates to about 500+ torch lumens. BUT, remembering that another CPFer (was it modamag?) announced that the stock mag switch had enough resistance to signficantly reduce the output, i think i most probably wasn't even looking at 500+ torch lumens. Still, like i said, this is my first encounter and i am amazed (my next best experience was a tri-lux T bin. Good throw but not nearly as bright overall)
Now for some questions. Without using a 3D mag, how can i improve the output from this current setup with the same potted 1185?
1) Can i use the 8AAs straight off the charger now that i am running them at spec rather than overdriving with 9AAs? Would that gimme more light output or smoke output?
2) What kind of added advantage would a Kiu's socket with bi-pin bulbs give me over the potted bulbs besides a lower chance of having bulbs blow up? (Btw, Is it really that easy for potted bulbs to go ka-boom?)
3) Where do i sign up for the incandescent appreciation club? :naughty:
Any help would most certainly be appreciated.
