What ideas do you guys have to get more fuel economy out of a car or truck? Besides getting it towed everywhere or pushed to its destination?
I think we all already know about inflating your tires to the proper pressure, gettting a tune up, clean air filter, carrying around only what you need no extra junk or weight in your car, no jack rabbit starts and to coast to a stop light incase you can hit the green before you stop. Then the myth busters showed to leave your trucks tail gate up and to drive with the windows up and AC off.
What about the computer chip upgrades for better performance? I understand those also offer an economy mode?
What about lower resistant tires?
Taller tires? Are taller tires good for less rolling resistance?
Higher rear end final gear ratios?
I was reading in a sign industry magazine where if you drive a truck for your job and do not tow, you can use a higher final drive to get up to 5 more mpg. Then the important of using OD, of course i hope everyone uses that.
What about reducing the capacity of your engine? Removing the push rods to a few cylinders in your multi cylinder V block engine to turn off a few cylinders. (Assuming you use push rods, unplug the injector if it has port injection)
What about using or making a body part for the front of your car or truck to make it more aerodynamic? Anyone thought to take a piece of lexan and screw it to the top radiator support and curve it down to your bumper of your truck or car that has a blunt square front end to make it a bit more aerodynamic?
What about those sport wings you see on the rear of cars? Fiber glass and carbon fiber hoods, fenders, doors, etc?
These were just a few ideas off the top of my head.
