Just got my Nuwai ALX 233C led light from Amondotech.
Fit & finish is nice and the size is comparable to a M@g 3D in length but the diameter is "C" sized. Flat tailcap so it will tailstand. There is a flat cut into the body to allow you to index the light to find the switch easily. The switch is just below the bezel and activates easily (short travel on the switch).
It has 4 modes of operation--100%, 50%, 25% + blink. The first 3 are available by a simple push of the switch and are in decending order of output. Blink is activated by holding down the switch for about 3 seconds. Light turns off by pushing the switch again.
The light is very white in color, especially on high power. It's whiter/warmer than my TM301-x3, with no unpleasant tints.
The light disassembles remarkably fast--it has o-rings where needed but no loctite (YEAH!). The star looks pretty neatly soldered and has Lumileds printed on it. The aluminum retaining ring unscrews easily giving access to the top of the star. Not wanting to damage it, I did not pry out the star to see what bin it was.
The reflector is half-stippled (lower) and smooth on the upper half. I think the lens is plastic and I may get a UCL to replace it.
No runtimes yet, as I don't have any NiMh C's. It's currently running on some 'heavy duty' cheapo C batts I had laying around.
--Vic
--Vic
