Ok, I got my new 3.0V RCR123A from E-lectronics store last week and did runtime test on MN03:
minutes / Lux at 1M
0 / 2890
5 / 1855
10 / 1839
15 / 2050
20 / 1890
24 /0 (battery protetive effect)
Conclusion: the runtime looks fine, but I finally would not recommend use 2x 3.0V RCR123A for MN03, because you need multi click first or you may burn the bulb, this is not convenient for emergency. The 3.0V RCR123A also short the bulb life, I did about 5 rounds runtime test, the bulb then died. I think I will keep use primary cell for my E2D, I can get 60 min with high brightness and 80 min for total use and don't worry too much about bulb life.
