The Nightblaster is one of those plastic flashlights that you find at Walmart (or such places) that has a 3AAA "barrel configuration" (so it's short), the rotating clip (so you can clip it to something and point the light in various directions), and turns on by turning the head about a 1/4th of an inch clockwise.
Mine had 3 red colored 5mm LEDs in it, and since it uses the 3 AAA cells, it has resistors for each LED to bring the current down to what red LEDs require.
Well, because I have seen that the MJLEDs don't do well when overdriven, and prefer about 3 volts, I decided to replace the three 5mm red LEDs with three of the SMJLEDs.
The light produces a pretty decent wall of light, . . . .slighly blue in tint, but very adequate in the amount of light outputted. Since these are replacing the red LEDs, these SMJLEDs may be just under optimal fV, but as they are, in this setup, I am quite pleased with the results. And being slightly underdriven, it will probably last a good long time in both output and LED life.
Comments?
BTW, if you just have to see pics, . . I'll try to get some over the weekend and load them here on Monday.
Comments?
