RipplesOfLife
So there I was looking for some cheap light to mod. Most lights that I see run on an even number of batteries, and the ones that do use 3 batteries were too expensive for my purpose.
Then I walked into a Dollarama.
Basically same design (perhaps less quality control) as an item I saw at CanadianTire, but cost only $1. It was perfect.
Original:
-Incandescent
-360 degrees lighting
-no reflectors
-3 x AA Batteries
After:
-10 mm 80,000 to 100,000mcd White LED
-360 degrees lighting, 180 degrees with homemade reflector, flashlight with top part removed.
-3 x AA Batteries
-Long runtime.
The current is limited by a resistor. The reflector is made using roughly polished pop cans. Initially, only the top and bottom reflector was considered, but then I found that I can't quite see well. The light source was closing my pupils. So aside from bouncing a bit of light forward, the side reflector's main purpose is to perserve some of my night vision.
Three different ways to use it.
Ultimately, the brightness depends on the resistor value used.
Original:
-Incandescent
-no reflectors
-3 x AA Batteries
After:
-3 x AA Batteries
-Long runtime.
