RipplesOfLife
Ok, I'm sure that this is nothing new, and that almost everyone on here has made one at least once in the past. I like this design because, it's small, bright, and cheap. Aside from a soldering iron, some solder and an LED, the rest of the material (two items) is relatively free. This is a 9V design.
Materials needed:
-LED of your choice
-Resistor (based on 3.7 V, 20 mA specs):
200 - 250 ohms if you want very long runtime.
100 - 130 ohms (over driven) if you want more brightness with a bit less runtime.
50 - 80 ohms (over driven) if you want even more brightness with less runtime. The resistor may feel hot!
(About 56 ohms is what I used. Measured amps with a some what fresh battery is about 73 mA. The resistor feels hot.)
(Please correct me about the runtime if they are not correct, they seem logical to me.)
-9 volt connector. I took mine out of a dead 9 volt battery. Make sure it says Mercury and Cadium free. And practice safety.
Equipment Needed:
-Soldering iron, 15 watts recommended, or be quick with a 30 watts.
-Solder, thin low melting recommended.
-Something to open a 9 volt battery. Skip this if you rather buy a connector, or if you don't have any dead 9 volts. I find that the connectors from a battery is less flimsy than "actual" connectors.
Only thing to worry about when making is short circuiting by the leads of the LED. Also, the plastic panel of the connector can melt by the heat of the soldering iron.
Compared to Arc-P AAA.
As bright as it is, my cheap light does not have a hard finish, it's not water resistant, the light itself is very pocketable but not the 9 volts, and it's not the most eye pleasing thing.
But, it is pretty good at free standing, and it's roll resistant.
Materials needed:
-LED of your choice
Equipment Needed:
