webley445
Got hold of one and thought I'd review it since all the others I have have probably been run into the ground. Output is dimmer than a PT Attitude. Aluminum body seems very sturdy, have dropped it [accidentally] several time and still going, no observed or obvious damage. Tailcap is flat so allows for light to be stood on end. There is a notch cut into the tailcap and a hole drilled for using a lanyard. looking at the LED's themselves, I turn it on [twist head] and look at them at an angle while they're lit. three of them look white, but the fourth is very blue. I can't help but feel that if that 4th one was white also the output would be a little better. Have seen this in other LED lights also. Overall an OK light if you can get one cheap. Wouldn't pay too much for it, maybe two thirds of half the cost of a Attitude due to its lower output. Also being a 3AA design, the body is a little long, although some may like it as there is some shaft to be able to hold onto [no snickering!]. Also due to its length it is easy to topple over if stood on end. Makes a good starter or gift to someone new to LED. I always reccomend giving lights that use easily available batteries to non flashaholics as gifts so they are more likely to keep using it if they have to be replaced. My rating system is different, it goes in three levels; HI-MID-LOW.
I give it a MID due to its sturdy construction, simple AA feeding. Just don't overpay for one [fortunately got mine for free].
