Northern Lights
The ROP LE originally claimed maybe the brightest in the smallest package hotwire and that is only about 600 torch-lumens, I quote:
"At this time I believe this may be the brightest 2C mod available. Please correct me if I'm wrong".-10-15-2005
https://www.candlepowerforums.com/threads/95327
Phillips 5761 available from several vendors looked like it could beat the 600 Torch-lumens of the Pelican bulb on 7.2 volts. Plugging the 5761 parameters into Welch Allyn equations you get this:
(spread sheet, courtesy of AWR's Hot Rater spread sheet bulb calculator!)
The problem in attempting this in a 2C size in the past has been the limited battery capacity; out of the 7.2-volt bulbs like the wa1111 and others the Pelican was the brightest available that would not over draw more than 2c, which is a problem with lithium batteries I am told.
941 Lumens goes out the front end. The lamp runs hot, 5.53 amps so with 18650's 2600 mAh you are pushing the issue just over the 2c draw, but you are close. With AW's new lithium C coming out it has potential. The 2600 mAh I got from BatterySpace.com. Calculations put the run time at 28 minutes, if you figure on AW's expected 3.3 Ah batteries you may get 35 minutes run time. The anticipated cost means that extra 6-7 minutes could costs about $20.
Well, my light is a working light and needs to go into service now, so I could not wait for the C lithiums but I can always build another or change when they come out. So I put together my 2CM61 using a UCL window, Litho123 SMO reflector, Phillips 5761, which BTW are .377 like the Pelican in diameter, FIVEMEGA PR>Bi-pin socket, two BatterySpace 18650, 2600 mAh. I also reworked the switch direct jumping the connections reducing the resistance and locking the slug down for focal point correction. The tail cap spring was replaced with an o-ring of the right thickness to snub the batteries that ride in a section of rubber hose. The tail cap snub is wrapped with three loops of de-solder copper braid. Tomorrow I will de-anodize the bezel and tail cap exteriors and polish them. These two areas get scratched the most and bright aluminum does hide those nicks.
It has a great beam pattern and works out better than my Mag Charger which is now a MC61.
FIVEMEGA's socket and one of his cammed smooth reflectors would fit perfectly to a particular job I have for this light. If only I could find the reflector.
This light cost $99 to make, changing to another socket and window I could get it down to @ $85 total.
Thanks to the posts and PMs from (and if I go up in smoke it is because I didn't listen to them!):
Alin10123
Litho123
FIVEMEGA
andrewwynn-AWR
Alin10123
Litho123
FIVEMEGA
andrewwynn-AWR
